Anyone here use this on your Z06? My neighbor is getting a free one from HyperTech for his 2002 coupe. It says on the HyperTech website that the same model is used for the coupe/vert/Z06. I was just curious if anyone here has used one and if so, what gains you acheived with a stock motor.
Thanks!!
I had one for my 2002 Z28 LS1 and they are garbage! :yeadog: The only thing that it really does is change for different wheel/tire size and rev. limeter. You can adjust the thermostat but I could never tell a difference. Oh yes and axle ratio. If it's free yes I would accept it! If I were to purchase a programmer, I would get a Predator or maybe a Superchips Programmer. Supposely you can do alot more and feel the difference! :cheers:
Hypertech Power Programmer III is pretty much a waste of money on standard shift car. On Automatic's you can change shift points. :cheers:
