This is a great forum. I spent most of the time searching the treads for information and have found quite a lot useful stuff. One of the mods I am looking at is cryogenically treating the rotors. Where can one find the machine shop / facility to do this? I live in the Dallas Fort Worth area.
Thanks in advance
I had Mallett do mine.....
.....But I have more info at home. I will post it to you this afternoon when I get home from work.
BTW I have done numerous Local , Div, and Pro Solo events plus Solo I Track time and the cryo'd rotors have not cracked or warped. I run a very agressive pad on the front and they generate a lot of heat in the Pro Solo events.
Thanks.:D
Doing research on Pads. Too many to choose from. :-?
Dave, You might want to check out Carbotech Engineering, they are on the web at www.carbotecheng.com
they are here in south Florida but deal nationwide. I have been very happy with their work, I also highly recommend their Panther Plus pads. If you need any more info let me know.
Jo Ann
Carbotech is awesome. I have used Larry's pads for years now. The panther plus compound is great. Great cold grip on the street and on the track no fade and good wear.
I also have had many years of slight heat crack rotors. Usually they work just fine but have debated about going to cyro rotors and I think larry does sell them.
