For removal of stubborn bug guts, bird droppings, tar, grease, etc....
Try Wd-40. Spray a little on the bug guts. Let soak for about 40 seconds
and remove with a clean dry 100% cotton towel. Repeat if necessary. Then
rinse with water to remove any oil residue from the Wd-40. Do not do
this procedure in direct sunlight! Do not use any abrasive polish or compounds.
If you use a product that contains abrasives you will put swirls and fine
scratches
in your paint finish.
If the bug gits are still not coming off. You need to use Z-18 ClayBar.
If you need info on Z-18 ClayBar and its use. Check my web site
Some bug guts are very acidic and will eat right into the paint. If you
have a couple of coats of Zaino on your car. At least the bug guts will eat into
the Zaino first..
This is a reply from Sal Zaino to an e-mail to him from me. I have yet to try it, but plan to.
CCRider
scratches
the Zaino first..
CCRider
