· Registered
Hi Guys, hey I know that this was already addressed, but I can't find the post /phpBB/images/smiles/icon_rolleyes.gif . Will someone give me the 1,2,3 process for changing my shift knob, Thanks /phpBB/images/smiles/icon_smile.gif
I Love my Z!! /phpBB/images/smiles/icon_biggrin.gif /phpBB/images/smiles/icon_biggrin.gif /phpBB/images/smiles/icon_biggrin.gif
· Registered
1. Remove the shift pattern insert by prying it out with a small screwdriver.
2. Remove the pin that holds the stock knob securely in place. Be careful as the pin will break. I've had the best luck by prying under a side edge with a screwdriver while pulling the top with vice grips. This works best if 2 people do it.
3. Unscrew the knob and take it off.
· Registered
1. (What SS said. Takes very little effort to get this out.)
2. I found that I wasn't getting anywhere with the screwdriver-under-the-corners method... But what DID work was locking vice-grips on the pin (get a GOOD HOLD on it, and lock it in tightly), and then using a long (sturdy) screwdriver to pry up on the vice-grips themselves. You get great leverage on the pin this way.
3. (What SS said.)
-Kirk
· Registered
Just be careful that you don't whack youself in the face with the vice grips when the pin lets go!
