To those of you that have went the cheaper route on a stroker engine....i.e iron block LQ4; do you notice any major difference in handling with the heavier front?? I think I read there was about a 75-100lb difference. Any cooling differences? Engine builder told me aluminum cools better..... :roll: I have no idea!!! I was wanting 400+ cubes but I really dont want to sleeve the LS6 (cause of sleeve problems people talk about) or mess around with knock sensors re-wiring of the LS2. So iron block has crossed my mind.
Your iron block thoughts....
Resleeving the Aluminum block with dry liners should not be a problem. Use an engine builder with experience such as Supporting Vendors: MTI or Cartech or ARE.
The iron block would decrease handling and increase weight on the front end (to be correct you would have to replace the front spring with a higher rate spring).
Aluminum does cool better than iron.
Keep the iron block for your truck.
LS2 is the way to go! The new LS7 will sell crate with an MSRP of like $19.5k and can be had as low as $12.5k but as good a deal as that sounds, it's only about $5.5k for a crate LS2. Considering that you'd likely be able to get a decent penny for your LS6 or could at least if your had it rebuilt to orig specs or whatnot, an LS2 is a great engine and I'd be surpirsed if the Caddy CTS-V doesn't have it next year as well.
A 6.0 Iron block weighs around 100 lbs more than a LS1/6 block. I have read reports that vary from 65-110 lbs :cheers:
