if you are talking about the 4' uv tubes on the inside of the gauage cluster im not sure if anyone makes a bulb for that.
Yes inside the gauge cluster. SO they are actually tube lights, not the small LEDS?
You could always experiment by adding some leds to the existing tubes (one on each side). When I added the metal rings around each guage for better looks I was disappointed that realativley little of the light reflected off the center two big rings(speedo-tach). Adding some leds would really make this nice I bet. :thumb:
