is or Z06 air bridge the same that comes on the base c5?
and did they change much from year to year?
thanx in advance, luis
Inlet and outlet diameters have to be the same because of the MAF and throttle body but they are a bit wider and higher over the radiator. Worth the money? Your guess is a good as mine. - C.
They are a waste of money, you can only get so much air past the TB (78mm). But they are good for blink-blink.
