HI there,
As of this post, there are no bulletins, or preliminary documents for this condition.
The only one that I see is the known bulletin for incomplete brake pedal return, due to a vacuum booster issue.
I checked 01 and 02.
You are clear, so let us know what you need.
Besttoyou, c4c5:eek2:
ZO6LS6 said:
ON Z CALIPERS STICKING??????:-?
No issues on the caliper sticking but there is an issue on bad brake boosters which I guess could give the same feeling and some 01 Z06s were getting them.
I had mine replaced under warranty. It feels as if your brake pedal does not come up all the way at times and you have to pull on the pedal with your foot to get it to return fully.
It was a huge difference when I got it back.
Don
guy's..........I am not having that kind of problem, or really any to speak of.....I am VERY easy on brakes..........
While washing the TOAD today, I noticed the right front disc, seemed to be a bit scored/rougher, than any of the others......
Not much, just a tad........almost imperceptible.......
But, I am a perfectionist.......and tend to not let things go by without notice.......:roll:
