1 - 18 of 18 Posts
Seems reasonably priced at the retail level. A little high on the miles for an `03 but if you are typical low-miles Z driver, the miles will correct itself over time - especially if you are going to keep the car.
Do a carfax.
See if you can get another 1,000 off. EB is such a gr8 color in this car!
Good luck and let us know! :coo:
BTW:
NADA "trade-in" is a number that dealers rarely, if ever allow!
Dealers take in cars at wholesale - and most of them use GALVES (at least here on the East Coast).
The only time you will ever see "trade-in" numbers from NADA is if there are programs/dealer incentives on the new car. :)
defender said:
BTW:
For what it is worth, every time I have traded a car in here in Houston (4 times), they gave me the NADA value - real simple, if they didn't I would have gone elsewhere.
Carmax is great at giving you a half decent rpice for your trade.
Price sounds good. Still, see if you can bring it down a little more.
If the tires are new or like new, I'd say it's a good price. If it's going to need tires soon, figure another 1200.00 for tires (OEM). :cheers:
It's a lot less than what I spent on the same basic car. I paid $4,000 more for mine, which has 7,000 mi. & only 9 more months of warranty. I would have jumped on your deal, assuming the car is very clean.
Z06 Power Adder Authority
Looks like a solid deal to me.
Not a bad deal but check the obvious things. Brake rotors must be clean without gashes or grooves. Check under the car to see if there is damage to the splash pans. Check the front fascia to see if there are any major gouges there. Check exhaust and make sure it actually is stock. Ask to see all the maintenence records. Ask if any recalls have been performed i.e column lock. A look under the hood will tell you basically how the car was taken care if. If it's clean 9 out of 10 times it was well maintained. If it's filthy, there ya go.
With 20k miles you are probably looking at a new set of tires in the next few months. Take that into consideration. Good Luck.
perfect list!
good luck on your purchase!
If you think it's good then it's good. I paid more than that for my TR '03 in October but it had 12K miles. Go get it if it looks good based on the earlier posts. I would pay $5K more for mine if I HAD to buy it again. :drunken:
1 - 18 of 18 Posts
