1 - 15 of 15 Posts
When putting the Z on jack stands (all 4 corners off the ground), where do you position the stands?
Which area will give most stability?
*I'm a bit nervous about lifting the Z this weekend - I'll be installing the new rotors.
I have 6 stands, all 3,000 lb. rated. I put stands at each jacking point with pucks. Then I leave the jack under the rear cross member with two additional jacks under the front crossmember. Call me cautious, but if I am near or under the car, can't have too much security. ;)
That's an excellent method. :cheers:
I use a similar method.
Reproman - Yeah, your cautious - but not having a Z on your chest is priceless. I once helped lift a '66 GTO off of a guy, and it was not pretty. :eek:
ZO6 AL-X said:
Always double-check everything when getting under a car too.
Alex
And when letting the car down. Always have to watch for errant jack stands, tools, and parts that could cause superficial but embarrassing damage as well. :eek::
I concur. :D
dryforkzo6-What kind of ramp is that under your Z? Do you park on it?
How is it made?
Pbalias-Who makes the jack you use? It looks like a heavey duty, low-profile, high lift jack? How high does it go?
Thanks,
Stumbo
How is it made?
Thanks,
Stumbo
The lift is made by Kwiklift and the floor jack was supplied by them. You can see them both with all specs @ kwiklift.com.
When the lift is not in use I park on it. Works great. :usa:
1 - 15 of 15 Posts
