I don't have this problem, but.... I let the car warm up to 100 degrees (coolant temp) before I even move it. Then I don't take it past 3000 rpm until the oil temp comes up. I've known people with LS1's that have beaten on them cold, and ended up sacrificing their cars to the piston gods!
-Speed
2001 QuickSilver Z06
Lowered,178 thermostat w/ fan controller, Ripper, !CAGS, B+B PRT w/ Speedway tips, TRIC one-piece with CF Cobra, GMS MAF, and TPIS long tubes
AOL IM: Speedshift
[This message has been edited by SpeedShift (edited 02-12-2001).]
Speed, guess I'm not used to having to warm up a car before moving it. Never had to do that with my big block 396 in my Chevelle SS.
Humm, well it doesn't sound too bad, I just baby it til it is warm. Only have 330 miles on it and all very easy goin miles at that. Appears from the posts in CF that it does occur frequently...try it and see if you hear it on yours.
BOBS
2001 Torch Red/Mod TR Z06
http://albums.photopoint.com/j/AlbumIndex?u=1520566&a=11496079
Zaino,CAGS defeat,Lloyds Z06 front/cargo mats,CAU decals,Z06 exhaust plate,Valentine 1/remote,BP Al Gas Pedal,power antenna,Dynamat Super interior,K&N air filter,Z06 TR Vette Rest,A&A frame savers.
Symptom: Cold engine only, and under load while accelerating at 2000+ rpm. Almost sounds like a diesel! Definite knocking going on. After warm no knock.
Also does not do this at idle or at rpms when not under load.
The service manual, Vol. 2 pg. 6-16 states:
Engine Noise Under Load
A cold piston knock which disappears in 1.5 minutes should be considered acceptable.
Appears this is normal. Everyone else have this noise?
Bob
[This message has been edited by BOBSZ06 (edited 02-12-2001).]
Yep, using the right gas...its not the pinging from detonation. Definite knock. although I didn't even notice it this AM? Maybe I'll put the pistol back in the holster for now.
Looking to purchase a second set of wheels so I can swap out street vs AutoX tires, but I'm uncertain how the clearance / fitment will work with C6 Z06 brake assembly. Can I still run C5 Z06 OEM? Do I move to C6 Z06 OEM? Other?
Current wheels are CCW C10s, front and rear both 18".....have...
1. I get a code of C1242, "BPMV pump motor ground open circuit' and 2. when pulling key from my ignition switch, my driver's seat goes to the ease of exit position. However, when unlocking with fob and putting key in ignition, the driver's seat does not return to the previous setting. Could it...
Looking at a set of new lug nuts, but the seller asked me what the "thread pitch" is (i.e, 1.25" or 1.5"). I have no idea what this is. Do any of you know what the thread pitch is for our lug nuts?
Bob
While at the track (first outing in 2019), my brake pedal began to go deeper in the stroke and approached the firewall. I’ve done the obligatory flush (5 liters of DOT4 using GM Tech2) which allowed me to complete one day of a two day autocross. I have replaced master cylinder TWICE with no...
We’re a forum community dedicated to the Chevy Z06 Corvette. Come check out discussions on performance, specifications, modifications, purchasing, maintenance and more!
