Hey guys.
I was just wondering if any of you changed out or got new stock knock sensors when you got a heads and cam setup installed.
Thanks for any information.
Harshil.
They're worth checking when you have it opened up, anyway. Water tends to collect around the sensors and they can corrode. I replaced both mine when I did the valley cover, for this reason.
I also had had to replace one on my 98 Coupe, for the same reason.
Your car will more than likely throw a knock sensor code after a cam install. Doesnt mean you have to replace it necessarily since the PCM picks up the new cam as knock.
BTW, i have 2 knock sensors for sale, new in box, PM me if interested.
