Just wanted to let everyone know that we are here and to let you know that we have an exclusive product that NO OTHER Corvette VENDOR HAS!!!
Our lighting specialist retrofits these kits to fit the C5 and Z06. Generic Philips HID kits will not fit unless retrofitted to fit factory sockets and fixtures.
As most of you know, the Z06's lighting is very poor and we are offering this kit to upgrade your Z06 to BMW type lighting. We have this kit installed on our C5 along with the PIAA 1100X fog lamps and they are absolutley awesome!!
We have installed these kits on a few Z06 Vettes so far and the results are great!!
If you want your Z06 to light up the night, read on:
PHILIPS HID (High Intensity Discharge) Lighting System for C5
Real HID Lighting System by Philips
High Intensity Discharge's light output is over 3 to 4 times greater than a halogen bulb, with less heat and power consumption. HID requires an electronic control gear and starter to momentarily apply high voltage to a capsule of inert and gases (including xenon) creating an intense arc of white light. HID emits brilliant white light. A 35W HID produces to natural sunlight compared to a 55w halogen. This translates into seeing farther, as well as better side illumination. HID provides better visibility and safety - especially in bad weather. The distinctive blue-white light of HID lamps stimulates the reflective paints in road markers, signs, and improves driver concentration. The distinctive look also makes your vehicle unique by standing out from the sea of other lights.
*Features
High performance driving beam pattern enhances factory head beam by increasing the distance of road illumination.
HID is more efficient at converting energy into light resulting in less drain on the alternator, and lower wattage. Same light level regardless of battery voltage(9-16 volts for 12 volt system). Longer bulb life, often outlasting the life of vehicle. Extremely durable and vibration resistant/ no filament to break. Runs much cooler than halogen.
Philips HID Retrofit kit includes:
* One pair of D2S or D2R Xenon bulbs
* One pair of Ballasts adapters to retro-fit your headlight housing, instructions, and wiring. (Ballasts and bulbs were manufactured in Germany and complete system kits are assembled in USA)
Back up by 5 years Limited Warranty
5 years limited warranty applied on ballasts and bulbs. Failure due to manufacturer's defect. (warranty would be excluded if kit had been improperly installed or visually physical damages is shown.)
These kits are priced at: xxxx, but are selling for up to: xxxx without the retrofit being done to them.
Let us know if you would like to upgrade to this great new kit!!
You can view our entire product listing by clicking: HERE
Thanks!
Shawn
Specializing in Performance Products for C4/C5 Vettes, 94-96 Impala SS and GM Truck/SUV's.
Company Vehicles:
1995 Black Chevrolet Impala SS
1999 Metallic Black Chevrolet Silverado Z71
2000 Summit White Chevrolet Tahoe
2001 Millennium Yellow Chevrolet Corvette Coupe
Coming Soon:
2002 Chevrolet Avalanche
"Your Speeding Ticket To The Finish Line."
The Los Angeles Performance Division
4854 Van Nuys Blvd.
Sherman Oaks, CA 91403
(877) THE-LAPD (843-5273) TOLL FREE!
(818) 501-DYNO (3966) www.TheLAPD.com [email protected]
Business Hours: Monday Through Friday From 9:00 A.M. - 5:00 P.M.
Pacific Time.
Saturday and Sunday: Gone Racing!
(We are in no way affiliated with the Los Angeles Police Department.)
[This message has been edited by L.A. Performance Division (edited 02-06-2001).]
[This message has been edited by N4C5S (edited 02-06-2001).]
This Philips HID kit is a plug and play and can be taken out within 10-15 minutes.
It is a must install unit if you want all the light output possible from your Z06.
Hope this info helps.
Shawn
Company Vehicles:
Coming Soon:
4854 Van Nuys Blvd.
Pacific Time.
I am very interested. Is the install difficult? Most importantly do you plan to post an install with step by step pictures so that even a dummy (like me) can do it? I am thinking about such how to guides like the ripper install. Without such a guide I doubt I would do it (so please say yes).
thanks
The H.I.D. kits that we have made for the C5 and Z06 are retrofitted so that they simply slide into the stock or Export T-84 headlamps fixtures.
If you install the H.I.D. kit with the stock plastic fixtures, you won't get any shaking at all since the factory setup doesn't shake.
If you install the H.I.D. kit with GM's Export T-84 glass fixtures, you will get a little shaking, but not much that is really noticeable.
You will have so much light on the road and you probably won't care that you will have a little bit of a shake with the Export T-84 glass fixtures. Again, with the stock plastic fixtures, you will have no shaking problems.
Jurow,
The installation takes no more than 30 minutes as this is a plug and play kit. It is like replacing your stock headlamp bulbs. No wiring or modifications is needed to install this kit. All you have to do is place your stock 9006 factory socket into the Philips ballast and place the Xenon lamp into the stock plastic fixture. You are done!!
All kits come with instructions and are one of the easiest installations you can do with such high results. The only task will be where to mount the Philips ballasts although they come with tough Velcro strips.
We also offer installation of the Philips H.I.D. by a certified GM electrical technician here in Los Angeles. Please contact us if you would like to schedule an appointment to have your C5 converted over to BMW type lighting.
Hope this helps.
Shawn
[This message has been edited by L.A. Performance Division (edited 02-09-2001).]
Shawn, do you know of anyone yet that has installed HID on both low and high beams? With a harness could I run both low and high together, I do that now with my setup, could I do that with HID?
------------------ Carl V. *****Authorized Zaino Distributor*****
Huntingdon Valley, PA.** 2000 Magnetic Red Convertible **
MN6,F45,QF5,AQ9,AG2,CJ2,T96,B34,AAB,UN0,U1S,JL4,UV6,T82,N37
** Corvette Club of Delaware Valley ** www.hcvind.com
E-Mail: [email protected]
[This message has been edited by hcvone (edited 02-10-2001).]
The reason why BMW and other high end luxury vehicle do not have high beam in HID is because HID systems take about 20 seconds before they come up to full projection power. High beams are mainly needed right away in dark areas or in emergency situations. This is what the low beams are only meant to be powered by HID.
I would recommend only going with low beam and then installing PIAA 1100X if you don't have it in already. This will give you more light than you can handle!!
Hope this helps.
Shawn
Shawn, yea I already have the PIAA's and I believe was I was one of the first to put them on a Vette a year and a half ago, I have installed about a dozen sets and they are great. Thanks for the info I have 130 watt high beams now but I an looking at options on my new car, thank you for the info
Thanks for the compliments. As you know, all of us here at L.A. Performance think the world of you. We were very sad when you were no longer at Xtreme. We are very thankful that you are back at Xtreme running things the way they should have the entire time.
If there is anything we can do to help you out, please do not hesitate to contact any one of the staff here.
Take care.
Shawn
One of my lights, well, basically melted, for lack of a better term.
In taking the ballast and bulb out, it appears as though, the little nipples that are designed to hold the ballast connector to the light had all snapped off.
Can I get the bulbs (almost) anywhere, or is this something that I need to order from you?
I hated having to take the lights out, but, with one giving me a nice strobe affect, and the other trying to set my car on fire, I had to remove em for now /phpBB/images/smiles/icon_wink.gif
You can get the bulbs from any Philip dealer or from us, but make sure you get the same type, 9006 or H4 depending on your set-up. The bulbs offered by us come with built in glare protection.
Please be extra careful when installing them.
Thanks!
Shawn
_________________
Specializing in Performance Products for C4/C5 Vettes, 94-96 Impala SS and GM Truck/SUV's.<P>You can view our entire product listing by clicking: HERE
When you're behind the wheel of your Corvette, the only things your hands should be doing are shifting gears, holding the wheel, and feeling the wind rush by outside. The C2 C3 C4 C5 C6 C7 Corvette 1963-2014+ Bluetooth FM Transmitter / MP3 Player / Radio / USB Charger Car Plug In Kit handles...
If you perform the smallest services to your Corvette yourself, you have always been overly cautious of the tools, hardware, and even your belt buckle wreaking havoc on your Corvette's Paint.
Now at Corvette Mods, we carry the latest line-up of stylish protection for your Corvette!
These C3...
Show off your Corvette with the C3 C4 C5 C6 C7 Corvette 1968-2014+ Custom Horsepower Decals.
This subtle, yet stunning decal can be placed anywhere on your Corvette, making your car just that more beautiful. The small pop of color draws people's eyes to your car, and lets them know you have a...
""FREE CENTER COMPARTMENT COVER ""
Purchase our "OEM VINYL/CARPET/BLACK PLEXIGLASS PARTITION AT $299.00" and recieve our center compartment cover for free! $150 value
We also have plexiglass inserts in OEM Colors-
Torch Red,Electron Blue,LeMans Blue,Millinium Yellow,Quicksilver,Machine...
Pumpkin Spice Accessories? How about NO! Simple savings on Exterior Accessories at PFYC - PartsForYourCar!
Too much pumpkin spice this time of year, don't you think? Us too. Forget that, just save $25 off of any $150 or larger purchase of mix and match Exterior Accessories by using promo code...
We’re a forum community dedicated to the Chevy Z06 Corvette. Come check out discussions on performance, specifications, modifications, purchasing, maintenance and more!
