Hi,
I'm installing a new clutch right now and in have LAPD external bleeder "kit". The hose seem to be a bit Too short to reach all the way to the engine bay.
Any notes of advise how to properly install it? Thank you much!
Quite simple actually. Remove the 2" long bleeder from the slave cylinder and replace with remote bleeder.
You run the line through the same hole in the bell-housing and continue up the back of the engine.
OK, done, i decided to not to run the line all the way up, even though i could, i think it will be easier to bleed the system with the hose hanging down.
Thanks guys!
KCMAGS said:
Your new line should be about 2ft in length & route along side your master cyl line.
I hear that 3' is barely long enough.
I had one made up at 4' length. Will install it next w/e when I drop the tt/driveshaft to have a look at the bushings/bearings.
Will report back on how the 4' fits.
What sort of fitting came on the end? Mine came with a hollow cap which ALWAYS leaves an air bubble. I need to know what type and size fitting to get for the end to facilitate bleeding. :screwy::mah:
Any help appreciated. :coo:
