First, my LG Longtubes finally arrived..:yeadog: Before I install them I'd like to put the bung in for my Wideband O2 sensor. Can anybody tell me exactly where to put the O2 bung? The last thing I need is to install the bung only to find out the Wideband sensor is bumping up against another component preventing the header from being installed.....Thanks in advance....
Call Lou, he would have put it in before he shipped them, if would have asked. He will still do it if you ship just the Y pipe back. :cheers:
IT L GO,
Actually, I did call LG and asked them to put in an additional bung for a wideband but something doesn't make sense. I was told by LG that all long tubes currently shipping are doing so with 4 O2 bungs to accommodate the rear O2 sensors in lieu of O2 sims (for those ordering with Random cats). If so, I must be missing something as there are two O2 bungs in the collectors (front O2 sensors) and 2 bungs located in the X-pipe. In reviewing the install instructions at LS1howto.com, the random cats are installed after the X-pipe. If that is the case, shouldn't the rear O2 bungs be located downstream of the cats and not in the X-pipe? I'm far from an expert but I was always led to believe that the rear O2's are there to evaluate the effectiveness of the cats and; therefore, should be located after the cats...Or am I wrong and the cats should be installed between the collectors and the X-pipe. I'm somewhat confused here.
Not sure since Lou went to the 4 bung system. I know for max HP the X-pipe goes ahead of the Cats. (old 2 bung setup). I also know that you can also put the cats on first and then the X-pipe (old 2 bung setup).
I agree with you that you need to have 2 sensors in front of the cats and 2 after the cats. Let us know how you make out. :cheers:
I spoke to Lou today and must first say that he is truly a pleasure to deal with. That said, he stated that in order to use the rear O2 sensors, the X-pipe should be downstream of the cats (Collectors-->Cats-->Xpipe). The only caveat being that this will result in a slight loss of performance. Since max performance is what I'm looking for I'm going to go with the cats downstream of the X-pipe instead and edit out the rear O2's. The plus side to this is I can now use one of the bungs on the X-pipe for a wideband. :)
Thanks, I agree Lou is top notch :cheers:
