Let me get this straight. If I buy a set of long tube headers(JUST the headers mind you) they will bolt up to the stock catalytic converters?
thats what I thought. So then I have to buy the high flow cats along with the long tubes in order for it to bolt up to the stock mufflers.
I think you are really best off buying a "system" that takes you from the headers back to the cat back system. One advantage is if you ever have to go back to stock it is just a bolt in. Some of the gain comes from the center section as well.
Don't the TPIS headers bolt up to the stock system? I'm obviously not sure. I should do some reading. :)
**edited** You have to cut and weld TPIS also. :(
Yep, :yeadog:
