G
Guest
·This spreadsheet show that you can tune out knock due to lean and low engine timing conditions.
This perfect tuning even included using injectors that were 25% larger then the stock ones.
See how clean the knock count is and at the same time got the timing up during WOT ( TPS >99.5)
Notice how the long term fuel trim is just about perfect when other then WOT.
http://teamzr1.com/cc2.html
This showed that it was not false knock or due to too much carbon within engine.
Ohh, in this run it was shown that setting the IAT to a constant of 75 degrees was best, not 59 degrees, so tuing IAT is just as important as tuning fuel trims.
John
John
