1 - 2 of 2 Posts
Z06 Tech Advisor
That bolt is a torque to yield design and once used cannot be used again as it stretched when torqued down
Since the head of that bolt is close to the steering rack to replace with a new bolt means the rack has to be moved to one side to give clearance to do this
Some try and cheat by using red locker on an old bolt,
but that does not work well and makes it much harder when needing to get that bolt out when need be
1 - 2 of 2 Posts
