If i get longer real bolts and cut the front bushings to lower alittle more, can I still fit ET streets in the rear??
Yep! They will fit no problem :z: :z:
17's no problem. 16's will need control arm adjustments.If you lower with longer rear bolts on 16" rims et streets you will likely notice some additional rubs that may call for additional adjustments. It seems like lower tire pressure makes them rub more also.
To run those 60 foot times, have you done any rear end work?? I am scared to break a shaft or differential.
