1 - 12 of 12 Posts
I went to lower my z the other day and found out it was already lowered on the stock bolts. It was like that when I bought it so thats what I was used to looking at. The front bushing have not been cut as far as I know. Should I cut them down or leave it how sits. I think the front needs to come down just a little more. If I cut the bushing will it need to be realigned just from that?
Looks perfect to me. If you go lower you will effect the ride quality IMO. :thumb: :thumb:
Lowering of any kind will effect the Alignment
Thats not low, this is low. This is my last truck I just sold. It was bagged and had a 3.5 body drop, the truck is sitting on the rocker panels.
It's hard to tell by that pic, but the front does look a little higher that the rear.
Discussion Starter · #9 ·
Nope, the whole length of the body is laying on the ground. I think it throws you off since the rear tucks a lot more rim than the rear. It is a little easier to see in this pic.
Did it sit on pucks or anything other than the rockers? Looks good to me. Now that's a truck the girls would like. Easy to get into.
D.J. :guiness:
Discussion Starter · #12 ·
It sat on the rockers 100%. You had to watch out when you lowered it down that there wasn't anything on the ground or it could bend up the body.
1 - 12 of 12 Posts
