I've done a lot of research on both forums, and I'm still a bit confused... Wonderin if you guys could give me your sage advice.. My Z definitely needs to be lowered.
I want to get the car .5-1 inches lower, without the front being higher than the back.. (I've read one tragic post about that - OUCH!!!)
In the front, I tighten the bolt until there's nothing showing between the bushing and the bolt..
In the rear, I probably shouldn't cut the bushing (would make it too low??), and just tighten till I see two threads showing on the top of the bolt..
Once that's done, immediately drive it - slowly - to an alignment shop to have them zero out the toe and, in my case, increase negative camber on the front wheels to about 2 degrees and the back at around 1.. (Autocrossing next weekend, want this set up ok)
Does this sound about right??? When I do this, I'll take MANY pictures - since I haven't seen any step-by-step pics of this procedure yet..
Thanks!
_________________
dimer0
2001 Torch Red Z06 [ anti-cagged | zaino | passport 8500 ]
2001 Black Audi S4 [ bone stock | zaino ]
Thanks!
_________________
dimer0
