I have a question that I know somebody will have an answer. When lowering the front end, you have two (2) bolts one on each side. Which direction do you turn them???
I have the car up in the air on stands now. If I take pressure off the spring I can turn the bolt very easy, but I'm not sure which way to go with it..
Any help would be great..
Thanks in advance,
Ernie
Turn them counter- clockwise (lookind down on them). This screwss the bolt up into the spring letting the control arm travel up higher in the chassis,thus lowering the car.
Thanks Baron,
That's what I thought but was not sure... It's a pain getting the car up and down just to find out that you went the wrong way...
Again thanks,
Ernie
Just another way to know you're doing it correctly: As you're turning, use your finger to be sure that you're CLOSING UP THE GAP between the leaf spring and the A-arm. You're essentially sandwiching these two things together. If that gap get larger, then you're turning the wrong way. :)
-Kirk
