1 - 20 of 43 Posts
Chevy's model forecasts are out for 2008.
They only show the 427 LS7 listed for 2006 & 2007.
For 2008 there are 2 new Corvette engines listed and NO LS7:
- LS3, 6.2L NA
- LS9, 6.2L SC
Possibly using the three valve haed ??
I'm guessing 450 HP & 600 HP respectively.
Credit to Rick Conti
For 2008 there are 2 Corvette engines listed:
- LS3, 6.2L NA
- LS9, 6.2L SC
LS9, 6.2L SC :jawdrop: Supercharged :D
Remember when the 6.4 liter motor was going to be in the new Z06 and it didn't make the grade...lot of time between now than then.
Banned
- LS3, 6.2L NA
- LS9, 6.2L SC
It makes sense that the "3" in LS3 would elude to the 3 valve heads.
They getting 6.2 liters with bore or stroke?
4" bore/3.622 stroke - 6 liter
4" bore/3.75 stroke - 6.2 liter
4.07 bore/3.622 stroke - 6.2 liter
I would think stroke.
Does that mean the the LS1 had 1 valve per cylinder and the LS7 has 7 valves per cylinder.. :D not to mention the famous 6 valve per cylinder LS6..that is why the Z runs so good.. :thumb:..crazy me.. :crazy:.. I was thinking that it was just the natural progression of sequential numbers..ie LS1, LS2, & LS3
- LS3, 6.2L NA
- LS9, 6.2L SC
thank-You!
I would like to see the ls7 exist for the C6 z06 for years to come. I'd imagine a supercharged ls2 would be great for the Coupe and convertible.
Superchargers are great for street cars...yet not quite as impressive as a 427 Naturally aspirated track oriented car.
I see a supercharged ls2 coupe with Z51 suspension for 56 grand...a base 425 hp ls2 for 45 grand...and a C6 Z06 with its 427 ci engine/aluminum frame/dry sump oiling system and larger wheels and tires as well as special body work for 66 grand...
I believe the early demise of the ls7 is incorrect. I could be wrong but I believe the engineering R & D costs could not be amortized in a two year or three year period...
The ls7 will be around for quite some time. Its not even subject to a gas guzzler tax ....which in and of itself is quite amazing considering 505 hp!
Time will tell whose right and whose not.
LS7's rule!
Banned
GM changed the name from LS1 to LS2 because of the generation change,
not because of a radical engine redesign.
I thought that GM would use the name "LS3" becasue of the unprecedented use of a 3 valve head.
But,
I guess I am an a$$hole.
Thanks for pointing it out. :roll:
But,
Lighten up man..I was just making a joke.. :thumb:
I think my step-dad had a Toyota Corolla 3-valve head, beater shop car in 1987. :p
Mercedes had a whole generation of 3-valve 2-twin plug heads. Just replaced this year...although the V8 is still in production, for a few more months or so.
My guess would weigh more to two cams in the block rather than 4 valves. It is just hard to meet passenger car fuel economy, emissions, and performance criteria without varying the cam timing.
Six speed manual trans Corvettes get 28+ on the highway and the new Z06 is supposed to get 24-25 w\no gas guzzler tax..that is pretty good MPG w\o complicating and adding weight to the good ol SBC.. :thumb:
1 - 20 of 43 Posts
