2001 Z06
Is it better to punch out the screen on the stocker or buy an aftemarket part like the Granatelli? I am not so sure I want to attempt to alter the stock MAF? Comments?
Screen
Nope, not gonna mess with it.................
Do not see a need to, and until I do, it stays stock as mud..........:D
JTB,
I know of no reason to take the screen out on the '01..........unless you are modding something that requires it......
Modding an '02, you put one IN, go figure..........
I read somewhere that the 01 MAF can flow more air than the engine is capable of using. They removed it from the 02 simply because they were trying to squeeze every last bit of HP from the engine and I believe the claim was a 2 HP gain with a screenless MAF. I wouldn't waste the effort unless you have an aftermarket intake. Even then I would recommend a recalibrated MAF supplied by whoever makes your intake system.
