Just got my magnetic drain plug from Ecklers. The factory plug takes a 10 mm hex drive to remove and has a washer to seal the plug. The magetic plug has a 3/4 head and appears not to require a washer. I have applied teflon tape to the threads. I don't see any way a washer could work with this new plug. Clarification and confirmation needed. Thanks.
Hey cowboy. It was not a problem if you notice the new drain plug has a tapered seat. You just snug it up and it works fine. I just did this last month. Don
Don, thank you for the information. I thought that was the case but just wanted someone a "lot" smarter than me to confirm and clarify.Thanks again.
No problem. I thought the same thing at first until I tried it and snugged it up. Good luck.
