I've got 500 miles now so I took you a'lls advice and had my oil changed.I asked him to install a magnetic drain plug and he said it already has one.Did I misunderstand but I thought somebody said they did not come with one.I don't know if it is possible but the car seems to be running even smoother now.
They do not
Hi there,
No, Corvette does NOT come with one.
You can get one from your local dealer. Just ask for one for a 00 Camaro, of 00 Silverado, and you will see the difference.
Best toyou, c4c5
Interesting....when I visited the Vet engine assembly plant recently the employee who drains the test oil said that ALL Vet engines get a magnetic drain plug before leaving their plant. I will be doing my first oil change soon, so we'll see.
BTW, the GM part number for the magnetic oil pan drain plug is 88891787.
Zippy :) :)
Mine did NOT come with a mag plug, but like noted above, my 01 Silverado did. Its a good investment, (the mag drain plug, that is) as I pulled filings from my drain oil at 400, 800, & 1200 miles. At 2,000 it was clean, and now with 3,000 I expect the same. BTW: no oil consumption at all. :D
