1 - 1 of 1 Posts
Vendor
aFe Power is a premier designer and manufacturer of automotive performance upgrade systems and components. Today we are here to introduce its new release for Chevy Corvette Z06 C7 - the all-new Black Series Momentum Carbon Fiber cold air intake system. These air intakes are designed around the largest filter possible for maximum performance and filtration. Their installation can result in 46 horsepower and 39 lbs. x ft. torque gains and a 25% airflow increase when compared to the factory intake.
A smooth one-piece sealed housing with an auxiliary air scoop is used to eliminate the use of multiple-piece housings and ensure the coolest air intake charge available. Your aFe Black Series Momentum Cold Air Intake System includes premium installation hardware and comes with a 2-year warranty.
Give your engine more go power with aFe Black Series Momentum Air Intake System!
aFe® - Black Series Momentum® Aluminum Black Carbon Fiber Cold Air Intake System with Pro 5R and Pro Dry S Gray Filter
Specifications:
  • HP Gain: Up to 46 hp
  • TQ Gain: Up to 39 lbs./ft.
  • Series: Black Series Momentum®
  • Filter Color: Gray
  • Tube Finish: Black Carbon Fiber
  • System Type: Cold Air Intakes
  • Material: Aluminum
  • Replacement Filter: Pro 5R and Pro Dry S # 21-90080
  • Airflow Rating: Up to 25%
Features:
  • High Quality One-Piece Roto-Molded Sealed Housing with Auxiliary Air Inlet
  • CAD-Designed Roto-Molded Intake Tube
  • Built-In Sight Window Provides Easy Inspection of Filter Without Disassembly
  • Unique (Patent Pending) Filter-to-Housing Interface for Easy Installation
  • No Cutting or Drilling on Factory Parts for Faster Installation
Includes:
  • Unique Computer Design Carbon Fiber Housing with Sight Window
  • Pro Dry S Oil Free and Pro 5R Oiled Air Filter
  • Dyno-Tuned Carbon Fiber Intake Tube
  • Premium Hardware
1 - 1 of 1 Posts
