Effective 5/30/2005, the following changes will be made to the Vehicle Order Guide:
Exterior section-(Q10) Wheels, Z06 silver painted aluminum, changed extended description to now read "18" x 9.5" (45.7 cm x 24.1 cm), front and 19" x 12" (48.3 cm x 30.48 cm), rear".
Exterior section-(QL9) Wheels, Z06 polished aluminum, changed extended description to now read "18" x 9.5" (45.7 cm x 24.1 cm), front and 19" x 12" (48.3 cm x 30.48 cm), rear".
Mechanical section-(LS7) Engine, 7.0L (427 ci) LS7 V8 SFI, changed extended description to now read "(505 hp [376.6 kW] @ 7000 rpm, 470 lb.-ft. [634.5 N-m] @ 4800 rpm), includes dry sump oil system"
Mechanical section-(FE4) Z06 Performance Handling Package, changed short description to now read "Z06 Performance Package".
Color and Trim section-(45U) Velocity Yellow, changed name to now read "Velocity Yellow Tintcoat".
Thanks, pls. let us know when you get a call from Rick. I'm on the too but +/- #174. He has had people drop out so I don't know where I am on the list. :cheers:
I'll let you know. I know he was up to #27 early this week.
Rick called this morning and I gave him my configuration.
He said I was #69 but a few had dropped out so I am actually
lower than that.
He said prices would be released at the end of this month and he would post on his website.
