1 - 10 of 10 Posts
pics of molding cracked on top edge of doors
The rubber/ plastic moldings on the top of the doors (the ones that wipe the windows) are cracked. This can be noticed on the inside of the door when it is open and at the most forward screw.
Has anyone one had this problem? Does anyone know of a service bulletin or recall?
Greg
This list is pretty current
Bulletins for 2003 Chevrolet Corvette V8-350 5.7L VIN S SFI
Service Bulletins
TSB Number Issue Date TSB Title 04-06-04-031 APR 04 Fuel System - Difficult Vehicle Refueling
04-06-01-013 APR 04 Engine - Serpentine Drive Belt Wear Information
04-07-30-013 MAR 04 Air Filter - SES Lamp ON/Multiple Driveability Concerns
01-07-30-036C MAR 04 A/T - DTC P0756 Diagnostic Tips
04-02-35-003 FEB 04 Steering - Steering Wheel/Column Service Revisions
04-08-50-005 FEB 04 Interior - Seat Back(s) Twisting
00-06-02-006A FEB 04 Cooling System - Coolant Information
02-07-30-001A FEB 04 A/T - 4L60E and 4L65E DTC P0894/P1870 Diagnostics
04-07-30-006 FEB 04 A/T - 4L65E, 4L60E, 4L60, 200-4R Oil Pump Spring
01-07-30-038B JAN 04 A/T - 4L60-E/4L65-E MIL ON/DTC P0757/Slipping
03-08-44-005B JAN 04 Audio System - Poor Radio Reception/Static
04-08-48-001 JAN 04 A/C - Broken Defogger Grid Detection
02-06-05-004A JAN 04 Emissions - Catalytic Converter Damage/Misfire Codes Set
04-01-37-001 JAN 04 A/C - Control Knob Replacement Availability
04-03-10-001 JAN 04 Tires - Puncture Repair Guidelines/Procedures
02-08-48-001A DEC 03 Windows/Glass - Urethane Adhesive Usage
03-04-20-006 NOV 03 Drivetrain - Rear Differential Fluid Leak
03-08-42-012 NOV 03 Lighting - Auto Lamps Operate Erratically/Inoperative
03-07-30-056 NOV 03 A/T - 4L60-E Oil Pump Identification
03-07-30-007A NOV 03 A/T - 4L60-E, 4L65-E Delayed Gear Engagement
01-08-42-001A NOV 03 Lighting - Lamp Condensation/Replacement Guidelines
01-01-38-013A OCT 03 A/C - Unnecessary Compressor Replacement
03-06-04-060 OCT 03 Ignition System - New Spark Plug Type/Gapping
99-09-40-005A OCT 03 Interior - Seat Belt Extenders
02-06-04-022A OCT 03 Engine Controls - PCM Reprogramming/Data line Diagnosis
03-00-89-021 JUL 03 Instruments - DIC Perceived Fuel Economy Settings
03-02-36-002 JUL 03 Steering - Revised Service Procedures
03-09-41-003 JUL 03 Restraint System - Proper Air Bag System Diagnosis
01-01-39-003A JUL 03 A/C - Catastrophic Compressor Failure Debris Removal
01-01-38-006B JUL 03 A/C - R-134A System Flushing Procedure
03-07-30-027 JUN 03 A/T - Oil Cooler Flushing Frequently Asked Questions
99-08-52-005A MAY 03 Keyless Entry System - Operational Characteristics
03-01-39-004 APR 03 A/C - Controls Intermittently Inoperative
03-06-05-005 APR 03 Exhaust System - 'Jingling' Noise
03-07-29-004 APR 03 M/T - Operating Characteristics
03-03-10-004 APR 03 Tire Pressure Monitor - Grommet Availability
99-01-39-007B MAR 03 A/C - Automatic A/C Functional Description
03-01-38-001 MAR 03 A/C - System Sealers/Leak Detection Guidelines
01-05-23-001A MAR 03 Brakes - Brake Rotor Lateral Runout Correction
02-08-42-001A MAR 03 Lighting - Polycarbonate Headlamp Damage Prevention
02-07-30-052B FEB 03 A/T - Oil Cooler Flushing Tool/Procedure
99-07-30-017A FEB 03 A/T - Oil Cooler Flushing/Flow Check Procedures
03-06-01-003 FEB 03 Engine/Transmission - Flexplate/Flywheel Replacement
03-04-20-002 JAN 03 Differential - Revised Output Shaft Seal Replacement
03-04-20-001 JAN 03 Differential - Revised Rear Axle Assembly Procedure
03-08-66-001 JAN 03 Body - Deck Lid Not Flush With Quarter Panel
03-04-95-001 JAN 03 Drive Axles - Revised CV Joint and Seal Replacement
99-08-64-016A JAN 03 Body - Weatherstrip Maintenance
03-06-04-012 JAN 03 Electrical - Wiring Harness Inspection Recommendations
02-06-03-006A DEC 02 Electrical - Testing Before Replacing Battery or Alt
02-06-01-038 DEC 02 Engine - Knocking or Lifter Noise
02-03-10-008 DEC 02 Wheels/Tires - Recommended Wheel Nut Torque
02-06-03-010 OCT 02 Battery - Parasitic Drain Information
02-06-03-008 AUG 02 Charging System - Low Voltage Display ON/Dim Lights
02-06-01-028 AUG 02 Engine - Crankcase Flushing Recommendations
02-07-30-028 JUN 02 A/T - Serial Number/Site Code Locations/Identification
02-09-41-001 JUN 02 Computers & Controls - DTC's Set When Replacing Modules
02-06-01-026 JUN 02 Engine - Identification Information
02-08-44-007 MAY 02 Audio System (XM) - Negative Impact of Vinyl/Cloth Roofs
99-00-89-019B FEB 02 Warranty - Parts Return Program Explained
I checked the list and called my dealer but no luck. I am going to get two on order under warranty. Do you think it would be tough to install myself?
Greg
I had the plastic piece crack, too. On the passenger window, near the blowout clip. If I recall, you couldn't just replace the plastic bezel, you needed to replace an underlying metal strip and the window gaskets, too. It was done under warranty. IMO, there's no reason your's shouldn't be, too.
Thanks Rocket Sled. I am going there in the morning but I hate letting them touch my Z. :roll:
Does anyone know what is involved in replacing these. I would like to attempt it on my own.
Greg
Thanks for the list of TSBs.
Alex
If the dealership does it and screws it up they still have to fix what they screwed up. I'd let the dealership do it. :z:
1 - 10 of 10 Posts
