Taking car to dyno today and tested out the system. The window switch is not working properly. I have set to come on at 3100 and shut off at 6100. Problem is that the nitrous only comes on at 6100. It does not come on at 3100. I got the yellow wire from the window switch goin to the white wire on the relay. I did as the instructions said. If this is wrong please tell me the right way to wire it. The white on the relay is the ground on which I want to do. The yellow on the window switch is the circuit ground wire..The pills are not backwards either. I got the 3100 in the "on" side and the 6100 in the "off" side..
What was it? Sometimes even stupid mistakes can help others learn... :cheers:
