I know I have seen alignment specs for a car that is used on the street and for DE's. I cant seem to find the ones I had before ( I searched the archives). does anyone have these, I am getting an alignment thursday and need specs. thanks.
I have my car aligned to -1.7* front camber, -1.2* rear, as much front caster as the tech could get, and 0 toe front & rear. This works pretty well with decent tire wear both street & track. I noticed a little of the outside tire wear so maybe a little bit more camber will be better. Maybe try -2* front and -1.5* rear...
Just a touch of toe out in front and toe in in the rear will help stablilze the car quite a bit and help it corner too. Zero toe on both ends and the car will wander going down the road.
