I just put my 80w/100w halogen bulbs in.Could somebody check on their car (with the headlights up) the plastic shroud that is held on with two screws on each sides.When I put it back together I now have a gap between the shroud and the top headlamp door.Thanks alot G.
Hi there,
Just remember, that you must install the tip of the top into the cover first, before you screw the bezel in.
Take a look, you will see what I mean.
Besttoyou, c4c5:z:
There is a slight gap. Maybe a little less then an 1/8 in. Normal GM tolerance. :)
