Just like the title says. I let my little brother use my z06 to go to the prom. When he got back you could hardly move the steering wheel(power steering?) and it was leaking fluid on my driveway.
My service abs,tcs, and AH light has been on the DIC prior to this. What is wrong? Any suggestions are greatly appreciated. (Going to visit Mr. Goodwrench on Monday, I just would like to know what is wrong prior to the visit.)
Please Help.
Sounds like a power steering hose is leaking. Don't drive it with the Power Steering reservoir low. Buy some Power Steering fluid and bring up to the correct level and if it not leaking to bad drive it to the Dealer. Obviously if it's leaking a lot, have it Flat-bedded. Let us know what the Dealer finds. :cheers:
I have had the same kind of problem on mine. It seems as if my car eats power steering fluid, but no more than it eats oil. I have had to reguarly check mine and definetly notice the sort of vibrating/grinding feel during lower speeds. Do most Z's have this issue?
