I need to lift the front end of my car so I can add a ZR1 front splitter and the front fascia reinforcement brace. Where do I place the floor jack so I can lift the vehicle and put it on jack stands. I read the manual and they show putting the jacking point in front on the transverse front spring on the engine cradle. That spot doesn't look as strong as the cradle brace aft of the front spring. I have a 2x6 that I will put between the jack and the frame to help dissipate the pressure point. I want to have both front tires off the ground at the same time so I can loosen the tire well liner to get the fascia off. I obviously don't have access to a lift of any kind, so the floor jack, and jack stands are my only option.
