Hi,
My 02 ZO6 has 19,000 miles on it. Just went out of warranty a couple of months ago. Now having the 3rd/4th gear grinding and stuck in 4th gear problems. I need some ammo to go to the dealer with so I can try and get it warrantied. Can you give me the TSB or any other numbers that would help let the dealer know that its a common problem?
I had one other issue with it getting stuck in gear about 6 months ago,, its been fine since then, so I kind of forgot about it and let the warranty expire. :mah:
*edit* I've read countless posts about the problem but couldn't find any actual tsb #'s.
Do a search and you will find pages and pages
TSB# 1230114 or PI 00597A
Keep us posted.
Good luck,
Alex
