1 - 1 of 1 Posts
Brand New Plug-n-Play Sequential Turn Signal Kit PFYC - PartsForYourCar.com!
These are the best quality, lowest priced sequential turn signal kits on the market. Not only do they use OEM style connectors and install in minutes, as an introductory offer, we're offering free shipping in the continental USA.
Use promo code SHIPMEFREE for a limited time to get your free shipping.
Click below to read more or purchase:
Plug and Play Sequential Rear Light Kit for Camaro and C5 C6 Corvette at PFYC - PartsForYourCar
Full description:
This plug and play sequential turn signal kit easily plugs into the brake/tail light bulb socket at the back of your Camaro or C6 Corvette. Two identical modules are included in this kit, one for each side of the vehicle. The sequential delay alters the outer turn signal (brake) light so that your rear lights appear to flash in sequence rather than together as they normally operate. There are plenty of videos to show how this works on internet video sites.
Here's how it works: The circuitry in this module produces a slight delay which causes your outer turn signal light filament to come on a bit later than the in-board turn signal light. When the signal blinks, a sequential step between the inboard and the outboard light displays an outward-flowing effect, as opposed to two bulbs lighting at the same time. The delay is long enough to display a sequential effect, but short enough to prevent a diagnostics "burned out bulb" error in the vehicle. Please note that your brake lights will both sequence outward when the brakes are applied.
Installation is simple: (The following notes are for Camaro)
  • Open the deck lid
  • Remove the access cover using a panel removal tool or thin screwdriver to release the plastic fasteners
  • Pop the fastener head upward and remove the fastener body
  • Inside the pocket, locate the 3-wire connector that plugs into the light bulb assembly. Press the top latch down and pull the connector from the bulb assembly.
  • Repeat procedure on passenger side
  • Test turn signals; you will notice a "sequential" flashing on either side.
  • Once both modules are installed and tested, replace covers and fasteners.
Application:
  • 2010 2011 2012 2013 Chevrolet Camaro (all models)
  • 2005 2006 2007 2008 2009 2010 2011 2012 2013 C6 Corvette (all models)
  • 1997 1998 1999 2000 2001 2002 2003 2004 C5 Corvette (all models)
To see a full line-up of our new 2005-2013 Corvette C6 items, please click here.
To see a full line-up of our 2005-2013 Corvette C6 sales and specials, please click here.
1 - 1 of 1 Posts
