Hi, I have a problem. One day I went to unlock my car and nothing. My key fob would not do anything except make the inside and outside lights turn on. If I try to lock it with the key fob the horn would just beep several times. The trunk will still open with the key fob but nothing else. Also I cannot open my windows either. They both have stopped working. I can use the lock/unlock button in the car. That still works. And under options I no longer have an on off next to autolock and next to easy seat entry I have – two dashes. I was just wondering if this has happened to anyone. One day this all happens and five minutes later everything will work. Very weird. Don’t want to take to Chevy yet for fear of a ding or scratch. Have had bad experience with them before.
Thanks Anthony:-? :-? :(
AJF:
Welcome to the forum!
Just a thought.....it might be a weak key fob battery, try replacing it, and see if that helps.
Zippy :z: :z:
Is it possible to re-program the clicker? I've had to do that on my Stang once or twice... Not sure about a Vette... yet ;)
Check the owner's manuel. It shouldn't hard to do.
Good luck!
-DW
