I just unscrewed the O2 sensor from the stock pipes. How do I separate the o2 sensor from the casing? The o2 sims I'm using have to plug into something. I'm assuming I have to take the casing off.
Thanks in advance.:)
if you follow the wires from the O2 sensor up, you'll come to a connector. Pull that apart, and put your O2 sensor in there.
