1 - 2 of 2 Posts
I have seen online several types of ODB splitter that will allow the connection of (2) modification units like the Valentine 1 Dashtronix and the new Dashlogic unit. Has anyone ever used this type of splitter unit? Or does anyone have a suggestion of a quality ODB splitter? My corvette is a 2007 ZO6. Thank you .
Z06 Tech Advisor
Be aware the DLC's pin 16 has none switched 12 volts and devices your plugging in might draw voltage when car is off causing battery drain
Also the devices if not turned off might be trying to talk on the car's internal network and can all the other controllers not to go to sleep drawing even more voltage when car is off
You need then to know before buying these devices if they can be turned off and when they are that they are not drawing the battery down
1 - 2 of 2 Posts
