Sabot you can't go wrong with an Odyssey. The cca on this model is 470 but stock is only 500 cca I believe. No problems w/cold or hot starts ever. At 25lbs it saves weight over the stocker, w/no possibility of an acid spill killing your pcm. Also invest in a Battery Tender if your car sits for more than a few days at a time.
We’re a forum community dedicated to the Chevy Z06 Corvette. Come check out discussions on performance, specifications, modifications, purchasing, maintenance and more!
