I have an 04 ZO6. The owner manual states 6 1/2 qts. I've read that when racing you can fill to 7 1/2 Qts. Under normal driving(getting on it once in a while) would it be OK to fill to 7 qts.? :-?
YES!
Charlie
Thanks Charlie! I figured it would be ok. I only put about 3,000 miles a year on the car. Instead of having 1/2 qt. sit on the shelf figured it might as well sit in the engine.
I automatically just fill with all 7 Qts. for just street use.
Jack
Jack
I let my car drain for 12 hrs or more... I put 7 quarts in. :z:
If you lift the rear end up 4 to 6 inches and let the oil drain well, then 7 qts should put the oil lever right on the "FULL" mark on the dipstick. :yeadog:
