1. Hit the 1900 mark on the new Z06 and took it in for the first oil change at the local Chevy Dealer. I usuallt buy the Mobil 1 and filter at a discount($30) then have the shop ddo the change and lube ($10). This time I didn't have time to shop and went to the dealer and told him "Lube, Filter, & Oil Change and use your Mobil 1 " as advertised.
Bill came to $70!!!!!
Worse yet the next day (Saturday) I washed it and opened the hood to dry out the channels and found drops of oil all over the right hand cowl. It first appeared that the attendant was a little messy with the dip stick and or oil fill. wipeg it off and preceded to dry off the inside hood edge. THE TOWEL SNAGGED ON THE BACK EDGE AND INNER BRACING NEAR THE LOCATER PIN HOLE!! TO MY HORROR THE INNER SUPPORT FRAME WAS CRACKED!!!! It appears now that the attendant slammed the hood with an empty Mobil 1 container laying on the cowl.
