1 - 12 of 12 Posts
I just want to know if below 60F is it normal that the oil temp on the DIC is off by 10 12 degrees ...
DFL
01 Z06 red/black
What are you basing that inaccuracy on?
Discussion Starter #3
Early morning ..temp in garage is about 34f ..coolant is 33f ..oil temp is 21f ....car hasn't been start for about 3 days
DFL
mgarfias said:
hehe
wait til its 15deg out and yer oil temp on the dic says "LOW"
LMAO
That was very funny!
also, "LOW" reading stays "LOW" much too long.....several minutes after coolant temp >150f, where I would expect oil to read >32f ...def screwed up sensor calibration through full operating range...IMHO
Let the car run for about 10 mins, then kill the engine and turn it back on. That seems to fix it ok.
The oil temp gauge is probaby more accurate at its upper range than its lower range. Alot of instrumentation is that way. Obvioulsly GM went for the accuratcy where it counts. Who cares if the oil temp is accurate when its thick as honey on a cold day? :D.
They both may be correct.. The oil maybe colder than the water/coolant!! It may take the oil longer to heat up than the coolant/water.
thx..yep, this does the trick:guiness:
MY Z IS A GARAGE QUEEN!!!!!
We have a heated garage and I've never seen it below 70 degrees. And as high as 76 degrees in the winter. Soooo, the oil temp is always 70-76 degrees. In the Summer, I've seen it reach 90 degrees. my Z has never been outside overnight.....
I've checked the thermometer in the garage against both the oil and coolant readouts in the car and there hasn't been more than a 1 degree variance :D
Barrie
1 - 12 of 12 Posts
