Seem to have developed a small 1 inch paint crack on my passenger door. It starts at the upper corner at the base of the window and end of the door above the door handle. Not sure what caused it and does not appear to be a crack in the body. That little tip of the door does appear to be a little thin. Anyone else ever encounter this problem? Recommended repair?
You can do a search but I havent heard of this before. Can try to have a pro fill in and buff- the worse would have to have door painted which I DO NOT reccomend-very hard to make look like factory. Find a pro. to fill and buff. :jammin:
Thanks for the advice. Need to do something and you are right about now painting the door.
