1 - 12 of 12 Posts
does anyone know [or can reference] the part # for the right front wheel speed sensor jumper harness?i'm getting codes for this & took it to the dealer today & they want $665 to replace it :eek2: so, i'm thinking of diy. thanx!
jub the invoice says "right front wheel speed sensor has excessive variation test jumper harness & wheel speed sensor ok @ this time - intermittent problem - most likely is a jumper harness i
went to gm parts direct & entered that # & it says "no match"
If it were me, I'd replace the wheel bearing, which contains the speed sensor. Just a hunch.
ok - got a part #?
Part number for harness. (#28) Don't know why GMParts direct doesn't have it. Maybe it has been revised.
As far as the wheel bearing is concerned, I think you can go to your local auto parts store and get a bearing next day.
jub-you da man!! thanx! :cheers:
For what it might be worth.I had to replace a left front cable. I think it was about $28.00
Tony #54
Discussion Starter · #12 ·
thanx to everyone! :z:
1 - 12 of 12 Posts
