Hi folks.
Recently posted about oil on the bottom of the ATI blower caused by PCV feeding into the air cleaner. I ran a test to make sure it was and PCV and not a leaky drain plug on the ATI unit. I unhooked the PCV from the air cleaner and ran the hose out the bottom of the engine bay. Well after 300 miles of driving, the blower is dry on the bottom. The tip I got from the service tech at ATI was correct. The PCV was the culprit. Just wanted to pass this info along, in case anybody was experiencing the same symptoms as me.
Cheers
Zrod
Cheers
Zrod
