I have this oil-like fluid seeping from a pinhole sized puncture shown in the blown-up portion of the photo. Can you tell me what is going on? I really don't even know that any fluids were stored in this housing.
o:
Yuk. :lol:GR8 WHITE said:Hmmmmm. I don't know, but did you check inside the well under the carpeted cover? Maybe there is a oil quart that is leaking and ate a hole in your plastic. Maybe? Other than that, i'd say you need to have your ride tested for an STD. :jawdrop: The "DRIP" Other than that....Looks REAL clean under there. :thumb:
THX for the kind words. :thumb:GR8 WHITE said:Hmmmmm. I don't know, but did you check inside the well under the carpeted cover? Maybe there is a oil quart that is leaking and ate a hole in your plastic. Maybe? Other than that, i'd say you need to have your ride tested for an STD. :jawdrop: The "DRIP" Other than that....Looks REAL clean under there. :thumb:
...not as quick as knowing I just dobbed it up with some towels and left it. :ity:ROSSO Z said:PS I couldn't help but notice that your rear anti-sway bar is not polished. That will get you banned in a heartbeat.
:z:
GR8 WHITE said:HOLY SHYT! I was RIGHT? Aw MAN! I am the MAN! I feel good now! Glad I can help out a fellow member.....Wow...what a good guess. After all the information that has been brought my way, I FINALLY was able to give back to the community. So, I guess you tested NEGATIVE! :cheers:
