1 - 20 of 22 Posts
I thought I should participate and post a couple of pictures. I hope you like them. Please forgive the dirty garage. It is too cold here for me to clean it out.
Ok Norm, what did it take this time to reach the MAX level on the dipstick? 6.5 or 7.0 qts? Mark:)
Discussion Starter · #11 ·
6.5 quarts to the top line.
Thanks guys. I love the lift. It is great.
But did he do a "Minute Lube" oil change, or a Z06 fanatic oil change. Did he raise the rear 4~6 inches (doubt it on the ramps) and let it drain 6 hours :D.
When I grow up I want to be Norm.:cheers:
Your website says it all.:cheers:
Discussion Starter · #16 ·
Thanks for the kind words but frankly, I don't ever want to grow up. :cheers:
Norm, thanks for the info. I guess it definitely has to do with the way you change your oil (i.e. if the you lift the rear to get every drop out, then you;ll need 7.0 qts, if not, and you do it the way the service manual recommends...being level...then it's 6.5 qts).
What do you think of that ZeeOhSix??
Discussion Starter · #18 ·
I absolutely love it. I look forward to the drive to work every day and when I get there, I want to stay in the car. hahahha
I washed the car last friday and let it set until yesterday. There was still water coming out the mirrors. hahaha
Norm, you must not be as anal as me...but I use the Wet/Dry Vac in the exhaust mode to blow all the excess water out of the nook and crannies after a carwash and then towel her down.:D
Norm...Norm...
Norm is my hero, the man has it ALL. I should list it, but I get depressed. In fact, this site combined with the current economy has me in deep depression.
1 - 20 of 22 Posts
