I noticed a bit of plastic wrap stuck under the rear window trim. This must be from the 'factory wrap' and did not get noticed by dealer. Also noticed a slight bit of sticky stuff on the roof, again probably from the plastic wrap. Any ideas about safely removing both of these? Thanks.:D
Discussion Starter #3
IMA Z06
Thanks for the reply.
I am a newbie here and I appreciate your directing me to the previous discussions on the wrap.
Cheers
I use One Grand Gum and Tar remover.Removed the residue from the plastic wrap like magic.You can get it at: www.carcareonline.com:)
Try Zaino w/ claybar.
One member resorted to Laquer thinner used sparingly and quickly, it did the trick in no time. Not for the inexpierenced though:eek:
:cheers: :cheers:
Discussion Starter #6
I called Zaino and talked with Sal who was very helpful about the question of the sticky residue from the plastic wrap on my Z. He suggested using a little alcohol and take it out.. it worked like a charm! And yes I sent Sal an order for some Zaino.
Cheers
Arch
