I know there have been threads about play in the steering wheel before, what have you guys done to fix it? is it a U joint that needs adjusting? a new steering rack? my car has almost 75,000 "not easy" miles on it :z:
Check the torque on the nut that connects the steering shaft, crank 'er down tight. If that doesn't fix it check your allignment. Mine was WAY off and made the turn-in feel very sloppy and gave the illusion of play in the system. Next would be the tie/toe rod ends, I'm just now replacin mine with the VB&P HD units. Lastly check the actual hubs for too much play.
We’re a forum community dedicated to the Chevy Z06 Corvette. Come check out discussions on performance, specifications, modifications, purchasing, maintenance and more!
